With Pro 3.5.1 released, what bugs are you finding?
263
2 weeks ago
RTPL_AU
Honored Contributor
Two bugs were formally found 3.5and addressed in 3.5.1
There are a few good ones in the Support KB:
https://support.esri.com/en-us/search?s=Relevance&version=3%252E5&product=arcgis+pro&cardtype=suppor...
Related post:
https://community.esri.com/t5/arcgis-pro-questions/arcgis-pro-3-5-bugs-found/m-p/1619162#M96150
What are you seeing in 3.5.1 that is new & exciting from a bug perspective?
RebeccaWatson1
Sharing layers with pop-ups on them has been inconsistent over the last few versions of Pro - namely overwriting a web layer when you want make a change (e.g. add another feature class) breaks the pop-ups in your web map. It is very tiresome to get everything to work again, often involving having to remove and replace the web layer entirely in the web map, which then breaks any web experience and widget connected to that the web layer. ESRI support told me it was expected behaviour (so not technically a bug) but it takes up loads of my time chasing these problems and resetting everything every time I want to share some new data so to me it is a bug.
Version 3.5.0 initially seemed to resolve the issue, allowing pop-ups to overwrite correctly without breaking other elements, but the version was unstable and crashed frequently, so when the patch came we updated to 3.5.1. Now the pop-up problems are back so I am considering downgrading as I have a preference for the crashing over reformatting web maps, experiences, and widgets repeatedly.
RTPL_AU
Honored Contributor
Error 010819 Spaces in Paths:
Using Pro 3.5.1.
When adding source data to a GP tool from within a map (i.e. not from Catalog) this error is shown.
The same data, same workflow in 3.3.x does not have this problem.
Drag & drop the same data from within a FGDB in Catalog does not create the error.
RTPL_AU
Honored Contributor
Using Pro 3.5.1.
Create New LAS Dataset cannot access a network share.  This error did not occur in 3.5 as I used it to create las datasets in the same project a week or so ago, before loading 3.5.1
I can create the dataset on a local drive, copy it to the network and use it as usual.
No updates or changes have been made to the file server.
RTPL_AU
Honored Contributor
Edited - Context menu (Find and Replace) not showing for editable table:
