Why is this SQL expression invalid?
1877
12-16-2021 03:39 PM
ChrisCowin
I'm upgrading a model that processes GPS Points. From the GPS device we can only get a table with every point, so I'm trying to create additional function that will go to the ultimate GDB and get the last date in the field "Start_Time" which is a date field. I achieve this by sorting by descending of this field and then "Get Field Value" from utilities into a date variable. Where I'm stuck is making the SQL expression using inline replacement to delete all the values that are lower than the variable I got from the server. However everything I've tried returns an error saying the expression is invalid.
Expressions I've tried based off this article:
Start_Time >= date %Last_Start_Date%
"Start_Time" >= date %Last_Start_Date%
Start_Time >= %Last_Start_Date%
"Start_Time" >= %Last_Start_Date%
Start_Time >= /'%Last_Start_Date%/'
 The value that the variable reports is:
2/12/2021 5:00:41 AM
I don't really know what else to try. Its really hard to understand why it doesn't work when the error just says it doesn't work.
jcarlson
What DB system are you on? That article references a few other formats for things like Oracle, Postgres, etc.
- Josh Carlson
Kendall County GIS
ChrisCowin
Just a regular old GDB, nothing fancy. I tried changing the variable to a string and then used:
Start_Time <= date '%Last_Start_Date%'
That seems to have worked, but think its a little odd I can't do that directly since its already in a date field.
AYamaguchi_UGRWCD
Still having this problem in 2025. @esriesri Plz fix! I'd like be able to use a date parameter without needing the SQL editor.
Thanks so much @ChrisCowin for the workaround!
Specific use case was: In Model Builder, using the Select tool where one of the selection criteria was [DateColumn] >= [user-defined, single-value parameter]
The only thing I could think of that might cause issue was that:
[DateColumn] has the format 'dd-MMM-yy hh:mm:ss.sss',
[user-defined parameter] could only be entered as 'dd-MMM-yy hh:mm:ss' when (data type=date)
(the trailing milliseconds were omitted). Wondering if the discrepancy in data format is what caused the issue?
