Why is ArcGIS Pro so slow?
1790
07-17-2019 01:49 AM
AliAzzouhri1
Is there someone who has difficulties to open data in ArcGIS Pro(too much slow ), or have some bugs problem with the program
@Dan Patterson
DanPatterson_Retired
Ali... possible sources
under nourished machine
large sized imagery
tools that are being used
basemaps
location of data (local, network etc)
Too many reasons why things may be slower than you want.
You can rule out some of the above, by repeating the workflow altering one of the above
  • repeat with a much smaller dataset
  • add to that, use the smaller dataset from a local drive
  • try with the small dataset on a better spec'ed machine
Details on your situation may provide some targeted suggestions
ThomasColson
MVP Alum
For 1&2, recommend calling tech support.
