Why Does KML to Layer Create an Offset?
681
05-26-2026 10:43 AM
rescobar
Whenever I run kml to layer or kml to geodatabase, if I reproject the layer to state plane, the result is offset. If I create a layer in WGS 84 and then project, I do not see the same offset. Sometimes, the layer is about 4 feet off toward the southwest, but other times, the change is not uniform. Is there any way around this?
Laura
by MVP Regular Contributor
Sounds like a WGS84 ↔ NAD83 datum transformation issue. Are you projecting twice - adding a layer to a map with a different projection and then also using the project tool? could cause problems.
rescobar
Do you mean a third projection? Does the projection a map is set do affect how the KML to layer tool runs?
I usually just have the map set to the state plane system I'm using.
Laura
What's the source of the KMLS? After running KML to layer, open the properties and confirm what the output coordinate system is. In map properties - is it automatically applying transformations?
rescobar
I believe the KMLs were exported from autocad. The latest I noticed this issue, I had my map in NAD_1983_2011_StatePlane_California_III_FIPS_0403_Ft_US. I used the WGS_1984_(ITRF08)_To_NAD_1983_2011. Looking at the raw dwg files I received, they show up as slightly off from the KMLs (about half a foot at most). Putting the map in WGS still shows an offset.
Laura
i know you said you've put it in WGS but is this a brand new map in WGS with no projection applied anywhere? If you add the KML there compare it to the original CAD data and see if they match up.
