Where is the option "Create layer from selected features" in ArcGIS Pro?
36758
13
12-19-2014 04:28 AM
VitorAntão
Hi, im using ArcGIS Pro and my impression are the vest. Unfortunetly dont find the option "Create layer from select features". Where can find it?
If the option doest existe , i hope that Esri Inc include this option in ArcGIN Pro because is a very important option!!!
Tags (1)
KenPierce
Here's my partial workaround. I want to have a subset of my original data to work on which would be the new layer in the old method. What I've done is add the layer a second time and instead of a selection I did a definition query on the second copy. Not great but worked for my needs.
KoryKramer
Esri Esteemed Contributor
Make Layer From Selected Features is included in the release of ArcGIS Pro 2.1.
Look for that release in January 2018.
MatthewForsberg
This is how I always do it as well.
MichaelVolz
Kory:
You say this feature is available, but does it work on all data sources?
As per this thread:
https://community.esri.com/thread/221433-make-layer-from-selection-not-working
This feature does not work on SQL Server and Oracle SDE databases.  It does work on file gdbs for me, but not for others so it is inconsistent.
What type of data sources were you using when working with this feature of Pro?
