Where is 'Quantities' in ArcGIS Pro
2176
04-08-2019 08:43 AM
Lebowski
Hello, I am trying to find a function that was in ArcMap in ArcPro.
In ArcMap, there is the ability to right-click a layer > properties and then select the Symbology tab. Then on the left hand side of window there is a choice for 'Quantities.' In the 'Quantities' window there is a 'Classification' box that allows you to break a field say into "X" number of classes. Does anyone know where this function appears in Arc Pro?
Thanks
KoryKramer
Esri Community Moderator
Hi Chad,
With the layer highlighted, go to the Appearance tab where you'll see the symbology dropdown.
Options for symbolizing by quantity are presented.
If you open the symbology pane from the layer (right-click > Symbology), you'll see the same options under Primary symbology:
And with an appropriate renderer, you'll be able to classify the data:
