When taking a feature service offline using "Download Map", Select by Attribute no longer works. Is this the expected behavior?
4020
11
05-08-2018 10:45 AM
ThomasColson
Followed the instructions in Take a map offline—ArcGIS Pro | ArcGIS Desktop  to set up a feature service for offline editing. Add it to a new map, but didn't download the map. Select by Attributes works great. Download the map (take the FS offline), and select by Attributes no longer works. Same expression as when I did it against the online FS. Validate won't even work. Just those 5 dots marching across the screen, over and over again. I looked through the documentation, and didn't see anything about some functionality being disabled when a feature services is taken offline (and it's now coming from a SQLite DB). But, perhaps the case, and I'm missing it in the documentation? (because that makes sense, SQLite limits what you can do with the data). I get the same result in Pro 2.1.1/Win 10, Pro 2.1.2/Win 10, and Pro 2.1.2/Win 7.
ThomasColson
I posted it in the Early Adopter forum under Geoprocessing, as that's the only version I happen to have available at the moment.....put it there 'cuz I went all Steven Spielberg and included a movie showing the workflow and the result.
KoryKramer
Esri Community Moderator
Thanks, Tom.  It all repro's with your data.  We're looking into it.
