What is the hierarchical structure of Arcade geometry types? Are they object oriented?
835
03-03-2022 04:52 AM
Bud
Esteemed Contributor
I'm a novice learning about Arcade.
From my limited experience, it seems like there is a hierarchical nature to Arcade types and subtypes.
If that’s correct, what does the hierarchical structure of geometry types look like?
- Geometry
    - Point
    - Multipoint
         - Points
    - Polyline
         - Paths
              - Points
    - Polygon
         - Rings
              - Points
    - Envelope
Also, are the types considered to be object oriented?
Bud
JohannesLindner
Are the types considered to be object oriented?
No idea how the types are implemented behind the scene, but if you take a basic interpretation of "object oriented" as
  • child class IS A subset of parent class
  • parent class defines some attributes and/or methods that get inherited by child class, so sibling classes have some similarities
  • child classes can define their own attributes and/or methods
then yes.
For Arcade, similar to the question about arcpy that you linked, the class hirarchy (the "IS A" relationship) would be
  • Geometry
    • Point
    • Mutipoint
    • Ployline
    • Polygon
    • Extent
Geometry would define the common attributes (type, hasZ, hasM, spatialReference), while the types define their own special attributes. Note that you can't use a Geometry object, but only the distinct types.
I wouldn't consider the rings and paths attributes to be part of the class hirarchy. They are components of their respective types, implementing a "HAS A" relationship (e.g. a Polyline has an array of arrays of points).
Have a great day!
Johannes
