what happens when you accidentally close a map or layout window in your project?
64663
9
02-10-2015 02:28 PM
GabrielYarlequé
so I am using ArcGIS Pro and I accidentally closed one of the map windows in my project (see picture). So are the maps, layout, scenes that you have open in your project saved somewhere or are they only saved within a single project in your C or D drive? I tried to browse back to see if those were saved somewhere else but I couldnt find them. What would you do in that case? or you just have to insert a new map, add the layers and continue with your work.
thanks
JakeSkinner
Esri Esteemed Contributor
Hi Gabriel,
The maps and scenes will be saved under 'Maps' within your Project pane.  See below:
JakeSkinner
Hi Gabriel,
GabrielYarlequé
thanks!
DianneYunker1
How to find this "Project Pane"?
TimOrmsby
Hi Dianne,
The name of the Project pane was changed to Catalog pane. (That should make it easier to find.) If it's not open in your project, you can open it by clicking the View tab on the ribbon and clicking the Catalog Pane button.
Catalog Pane button on View tab
DianneYunker1
Got it.  Thanks!
IgorMacedo
Just passing by to say that this post is a life saver!
PeterDavies
That was very handy
AbhinovAbhilekhDutta
This stopped me today from smashing my system:D Thanks a ton!
AlexBurtonJohnson
You and me both.
