What happens to definition queries after importing an mxd to Pro?
1446
05-26-2023 02:42 PM
ErikFernandez
Just recently transitioned from ArcMap to Pro. When I import an mxd into Pro, definition queries seem to still be working, but I can't find where they are. I'm looking at filter through symbology pane and through select by attribute, but I can't find where the old queries are hiding. Thanks in advance for any advice. - Erik
KoryKramer
Esri Esteemed Contributor
Hi @ErikFernandez
Open the layer properties > Definition Query
https://pro.arcgis.com/en/pro-app/latest/help/mapping/layer-properties/definition-query.htm
Does that work for you?
KoryKramer
Hi @ErikFernandez
ErikFernandez
That does the trick, thank you. Not sure how I missed that. Lesson learned in the process, display filters are different than definition query, but similar.
