WFS Bounding Box
3778
03-12-2019 08:10 AM
EricArmitage
I understand its possible to read features from a WFS layer using a bounding box in the connection parameters to limit the number of features read.  I'm struggling to get that to work.  Does anyone know how to do that?  I've tried setting BBOX as a connection parameter but I get a message saying it conflicts with ArcGIS reserved parameters.
Tags (3)
BruceHarold
Esri Frequent Contributor
Hi
I believe BBOX support requires Pro 2.3, please check your release.
Here is an example parameter setting on a connection.
It should be in the default feature coordinate system, which you can inspect in the capabilities document.
EricArmitage
Thanks Bruce.  I have Pro 2.2.0 so maybe that is the issue.  If I put something in the BBOX parameter as you have done the OK button is greyed out
