Webpublish error code 500
3856
12-08-2020 02:20 AM
Alexandra_Luisa_HøjgaardWood
Hi, I am currently trying to publish a large amount of datasets, and for most of them it has been successful, but a handful comes back, first with the error code 999999, and when I attempt to publish them individually, the error message comes back with:
{"error":{"code":500,"message":"Service Hosted/Fig_66_National_park/MapServer not found ","details":[]}}
I'm not sure why, as the majority of the datasets were successfully uploaded. I've tried to look into the error message in different forums, but it has yielded no results so far.
Can anyone help explain it to me, as I apparently am not smart enough to comprehend 😉
DanPatterson
MVP Esteemed Contributor
Search - GeoNet, The Esri Community
Had a number that were "solved", had you seen those?
... sort of retired...
I did, but I couldn't find the solution to my problem. I might just have misunderstood what the issue behind my error message is, but I cannot figure it out.
GlenShepherd
@Alexandra_Luisa_HøjgaardWood
If publishing to ArcGIS Server/Portal (Enterprise).... You may like to look into the ArcGIS Server logs.
If we're receiving the following:
  • ERROR 002555: The ArcGIS Data Store (relational) is in read-only mode and new items cannot be published
  • ERROR 001369: Failed to create the service
You may want to look into re-setting the ArcGIS Data Store mode: https://support.esri.com/en/technical-article/000022570
And then restarting the ArcGIS Server PublishingToolsEx service by logging into the ArcGIS Server Admin endpoint and navigating Home > Services > System > PublishingToolsEx > and stopping and starting the service.
DuongHB
Me got the same error message but in a running AGS, not when publishing. The issue may come from connection between AGS and Data Store. Validate Data Store is still OK, describedatastore.bat is also OK.
A bit issue I found is the Pooling of some services in Hosted folder is not correct (min-max instance is 0-0), but after adjust correctly the issue still there.
Some trying like repair Data Store, AGS, re-connect between AGS and DataStore still not work.
We're finding solution...
