WARNING 003237: Join had no matches
10715
01-10-2022 09:06 PM
Spatialelement
I'm trying to perform a very simple join in ArcGIS Pro V2.9.0 and am getting "WARNING 003237: Join had no matches".
I've checked the raw data for any blank values etc. I've indexed my join fields. I've converted my incoming CSV to a table stored in my projects default geodatabase. Nothing seems to be working.
I have also manually checked my data and have confirmed that there are values that match.
I'm trying to join a CSV to a shapefile. It has worked before (November 2021) and I am just performing the same steps, running the Add Join geoprocessing tool. I just can't work out what's going wrong.
IlkaIllers1
I've had joins fail before because of extra spaces I wasn't aware of - using the trim function in Excel on the table helped with that.
Also, check if they are stored as the same data type - I have had trouble with joins where numbers weren't stored in the same format.
