Voronoi Map
7118
7
08-23-2019 08:01 AM
CUARTA_OPORTUNIDADLOCAL
I need to make a map of voronoi from polygons about a certain attribute in arcgis Pro, since it is an arcmap function and I need the same function in arcgis pro and I can't find it
VictoriaAnderson
Is this what you're looking for? Which function did you use in ArcMap?
Create Thiessen Polygons—Help | ArcGIS Desktop
Thiessen polygons only works with points, not with polygons
In Arcmap
With Geostatistical Analysis -> explore data -> voronoi map.
KoryKramer
Esri Esteemed Contributor
Geostatistical Analyst‌ anyone here able to contribute to Liliana's question?
Thank you!
EricKrause
Hi Liliana,
Unfortunately, the Voronoi Map tool is not available in ArcGIS Pro.  Most Exploratory Spatial Data Analysis (ESDA) tools from ArcMap are available as charts in ArcGIS Pro, but the Voronoi Map is not one of them.
-Eric Krause
Thanks, but Do you know another similar tool to voronoi map in Arcgis pro? or another idea that help me.
EricKrause
Hi, I just noticed that you were asking about creating a Voronoi Map from polygons rather than points.
If you just need the geometry of the Voronoi Map and do not need the local statistics, you can do the following:
  • Convert the polygons to point centroids using "Feature To Point" geoprocessing tool.
  • Use the centroids as input to "Create Thiessen Polygons" tool.
  • Optionally, clip the Thiessen polygons to a boundary using the "Clip" tool.
This will give the same polygons as the Voronoi Map ESDA tool in ArcMap.  Again, it will not have the local statistics, but it will create the same polygons.
But i need the local statistics, in this case you know another similar tool?
