Visualizing Longitudinal Data
455
04-29-2026 07:51 AM
HWhitty
I have a dataset that is structured like this:
FYCountyStatAStatBStatC
2023CountyA123
2023CountyB234
2023CountyC345
2024CountyA456
2024CountyB012
2024CountyC123
2025CountyA234
2025CountyB345
2025CountyC456
...and so on for many counties, across many years.
I would like to create some interactive visualizations for this dataset, eventually in the form of a web app, but don't have much experience with time enabled layers or even just longitudinal data in general. From my understanding of time enabled layers in ArcGIS, I will need to change my dataset to look more like this, so that each county has only one record:
CountyFY23_StatAFY23_StatBFY23_StatCFY24_StatAFY24_StatBFY24_StatCFY25_StatAFY25_StatBFY25_StatC
CountyA123456234
CountyB
234012345
CountyC
345123456
Is my understanding correct? And is there a smarter way to go about visualizing this data that doesn't require reformatting?
DanielFox1
Hi @HWhitty
With the table at the moment I can't see why you can't use this format once you have joined the data to something spatial, date filters should be able to identify the date field or you can specify.
AlfredBaldenweck
MVP Frequent Contributor
You may also want to look at Transpose Fields (Data Management)
