Value doesn't fall within the Domain even though the field is already filled there ?
2443
14
09-16-2025 11:33 AM
DEAF_PROBERT_68
Honored Contributor
Hey all !
I have a question about File Geodatabase. I added  a lot of fields first and then when I made a select of a feature.  I  entred the name of it  in an attribute field.
I realized that it will be a lot of work , so I decided to proceed and add Domains for each field and then add a descripton.
The description names were came from a webpage that I put in the descripton.
When there is a new one I need to add , I went back to the Domain again and then add the new description.
Then I went back to the MapView again and selected a new feature and sometimes I get these.
Funny thing is why does it do that even though I scroll down each feature and all of them in the Allowable Equiment is already filled ?
So I googled for a solution to thins and I found this link https://support.esri.com/en-us/knowledge-base/error-failed-to-create-feature-class-name-value-doesn-...
Do I need to go back and re-selected again to solve the problem ?
I am using ArcGIS Pro 3.3.6 in Citrix and Recreation.gov .
If anyone in here has a similar issue and if it workied in FME  let me know.
I will be adding more like this for other campground in a few ranger districts down the road. For now, I am concentrate with one of our ranger district.
DavidPike
MVP Notable Contributor
Can you share your Coded Values and Descriptions?  It may match your Description but not your Coded Value.  Also look out for slight differences or trailing spaces.
DEAF_PROBERT_68
Honored Contributor
For Fields
For Domanis
For Subtypes
CalvinHarmin
MVP
I think you accidentally pasted the Subtype screenshot twice -- can you paste the domain menu screenshot showing the domain code/values you are having issues with?
JenniferCadkin
Something that may help you as you track this down...if you are needing to edit the feature's attributes and the error is preventing it,  uncheck 'Enforce Attribute Validation' in the Backstage Options, Editing tab.  With this option unchecked, there will be warning notification, rather than and error notification, and you will be able to modify the data.
https://pro.arcgis.com/en/pro-app/latest/help/editing/editing-options.htm#ESRI_SECTION1_9E23F817ABB7...
CalvinHarmin
MVP
I find when diagnosing the warnings like you're seeing where domain coded value is not being recognized in a selected feature:
For that layer in your map, if you open the attribute table, there is an option to specifically show domain CODE values instead of DESCRIPTION values. This also changes the behavior of what you see in the attribute pane (but not pop-ups, I believe; you have to change that field value display behavior separately by using an arcade expression to show the domain code value rather than description).
This at least helps you see what the 'actual' value of that field is.
Changing domain description values in the domain  menu should automatically reflect the new description value in your attribute table/attribute pane, unless ArcGIS Pro is being glitchy you may want to close and reopen the project.
However, if you change any domain code values, you have to manually update features that need to have that new code value applied.
DEAF_PROBERT_68
Honored Contributor
Thank you , Yes I see glitchy here because it does not refresh very well.  I see some issues when you change field in Unque Values and I see duplicate here.
It is like you said you have to close the project and then re-open the project to make the change or glitch disappears.
This morning I opened the project and I don't see anything strange in Unique Values...along with the show count.
CalvinHarmin
MVP
Can you say more about this - I'm not sure what you mean:
DEAF_PROBERT_68
Honored Contributor
Look at the picture scroll down here.  Look at the Site Accessible and I have two "No"'s and when I fixed it and refresh the count  One of the No count changes to zero.  It means the No now have only One label...
Example I just fixed Check-In and it does not refresh the Value "1" because I move the clock 2:00PM  from Value 1 to 2:00 PM
DEAF_PROBERT_68
Honored Contributor
I am reviewing again here and found some strange here ....
In that picture you see I have two separate No here.. that is the problem...
