Using Wildcard in select by attributes
6714
05-11-2022 06:41 PM
DanRichert
I'm trying to use the % wildcard in select by attributes using SQL. It's a simple query. When I use it with a FIPS number it works but for some reason other fields with other numbers don't work. Every time I get ERROR 000358: Invalid expression.
Here is the SQL expression: VACANT LIKE '2%'
I'm just looking for the numbers that are in the 2000s.
AndyAnderson
FIPS numbers are text, and that’s the only type of field where '%' works. Do the other fields contain text representations of numbers or actual numbers? If the latter you need comparisons like VACANT >= 2000 AND VACANT < 3000.
— Andy
DanRichert
Ah that makes sense. I didn't check and compare data types. I just created a new field and populated it with the VACANT field and then changed it to a text data type and then the wildcard search worked!
Thanks for getting back to me so quickly and for the helpful feedback!
JoshuaBixby
MVP Esteemed Contributor
Creating a new field, or even casting to TEXT is unnecessary.  If the numbers are integers, you can rely on basic integer math to find all numbers within the 2000 range:
VACANT / 1000 = 2
