Using Strip Map Index Features In Model Builder
1727
10-04-2023 06:20 AM
cdevault_pickett
I am trying to use the Strip Map Index Features tool in a model. Unfortunately when doing so, the page size settings reset themselves as shown in the attached screen capture. Currently running ArcGIS Pro 3.1.3. Has anyone else experienced this?
(view in My Videos)
CarlMorrison
Not sure I understand what you are asking.  Are you experiencing the issue where the settings in the Layout Properties/Map Series/Map Extent do not lock to the scale you set?  If so, a work-around is to add a field and populate it for each feature with the scale, then select Use Scale From Field.
CarlMorrison
Sorry, all I could see was the image when I first looked at this.  What happens if you un-check the Use Page units and scale?
cdevault_pickett
No worries, it was a GIF that didn't play as I hoped it would. So there was a little delay between first posting and saving my screen capture as a video.
