Using FME to save selected layer cause zigzag in ArcGIS Pro ?
539
08-06-2025 10:54 AM
DEAF_PROBERT_68
Honored Contributor
I am working on to getting my arc segments in FME to ArcGIS Pro but it is causing the segements to break up zigzag .
The arc segments were done by a autocad user and they are in DWG....
Results after saved to a new DWG shows this :
Has anyone had any luck using arc segements preserved to lines in ArcGIS Pro ?
It is possible there are might others may have the same sitution.
DEAF_PROBERT_68
Honored Contributor
Never mind. I post the same question on their FME Community forum and got an answer back; however, I had found that a transformer to make it work the line smoother and it worked.
