Using Calculate value for an sql statement
1293
02-01-2023 12:00 PM
Labels (2)
KitTompkins
I'm trying to use calculate value to create an sql expression for the Make Query Table Tool, and I've reached a point where I don't know why it's not working.
Here's my calculate value:
Expression = sqEX("%Name%")
def sqEX(Table):
	fEx= "{}.Owner IS NOT NULL AND {}.Owner NOT LIKE '%FLO%'".format(*Table)
	return fEx
And this is the error message I'm getting back:
Executing (Calculate Value):
CalculateValue sqEX("ssSystemValve") "def sqEX(Table):
return fEx"
"SQL Expression"
Start Time: Wednesday, February 1, 2023 11:41:31 AM
Value = s.Owner IS NOT NULL AND s.Owner NOT LIKE '%FLO%'
As you can see, the expression is showing the variable from the name field correctly, but then not passing it correctly to the string... I think it has something to do with the asterisk, but if I don't have that, it fails because there are two arguments in my format... thing. Do I need to write Table twice? Is there some other less stupid way to fix this problem?
Tags (3)
RhettZufelt
MVP Notable Contributor
With python 3, f strings seem to work much more reliably with string substitutions like this.
def sqEX(Table):
	fEx= f"{Table}.Owner IS NOT NULL AND {Table}.Owner NOT LIKE '%FLO%'"
	return fEx
Since your code is assigning %Name% = 'ssSystemValve', I just substituted that for testing:
R_
RhettZufelt
def sqEX(Table):
	return fEx
R_
