Using Arcade to calculate xy geometry.
22511
14
11-21-2019 10:36 AM
AbiDhakal
Hello GIS friends,
Is there an arcade expression I can use to calculate xy values for a point feature? I am using this (return Round(Geometry($feature)x, 6) expression, but it is not doing the work. My field name is Point_X and Point_Y.
Thank you very much,
Abi
Tags (1)
XanderBakker
Esri Esteemed Contributor
Hi Abi Dhakal ,
You are missing a dot "." in the expression, It should be:
Round(Geometry($feature).X, 6)
... but if it is working for you, then I assume it is just a typo.
You are mentioning WKID 3857 (Web Mercator Auxiliary Sphere) and that you want it in meters. However, this is a spatial reference that already return the coordinate in meters. If you want to obtain decimal degrees (WGS 1984) you can use a conversion to get that. See example here: https://community.esri.com/message/806053-re-latlong-unit-conversion-with-arcade?commentID=806053#co...
AbiDhakal
Hello GIS friends,
This expression worked for me, but it is in meters. How can is change it to  WKID 3857 from within the expression?
Thank you.
Abi
XanderBakker
Hi Abi Dhakal ,
AbiDhakal
Sorry. I meant to say I have it in NAD_1983_UTM_Zone_16N and like you mentioned I want to obtain decimal degrees (WGS 1948). Would the same expression work with the OriginalShift and all? I'm actually trying to create an attribute rule for the xy fields to auto populate.
Once again I'm sorry for the confusion.
Abi
XanderBakker
Hi Abi Dhakal ,
Unfortunately in Arcade you do not have access to any projection library (yet?). For this in ArcGIS Pro, you can use Python to do the job. Using a projection in a field calculation on a feature basis, might not be very fast. Depending the number of features you have, you might first want to project the featureclass, calculate the X and Y of the geometry and than join back those fields to the original featureclass.
AbiDhakal
@XanderBakker
I'm sorry Xander, please accept my apology for not clearly stating what I'm looking for.
1. I'm trying to get WGS84 values in decimal degrees for a feature service that is in NAD 1983 UTM Zone16N .
2. I'm also trying to get WGS84 values in decimal degrees for a feature service that is in USA Contiguous Albers Equal Area Conic USGS.
So those are two different calculation for two toally different situations.
Thak you,
Abi
AbiDhakal
Hey Xander,
Morning!
What I am trying to do is create an attribute rule where by any point collected automatically also has its xy calculated in decimal degrees. Is that possible?
Thank you.
Abi
XanderBakker
Hi AlabamaForest ,
Currently, that is not possible if it requires a projection of coordinates.
AbiDhakal
Thank you very much Xander!
ScottKichman
I do these attribute rules for a federated service
Coordinates
//Latitude
var y = Centroid($feature).y
var originShift = 2.0 * PI * 6378137.0 / 2.0;
var lat = (y / originShift) * 180.0;
lat = 180.0 / PI * (2.0 * Atan( Exp( lat * PI / 180.0)) - PI / 2.0);
return lat
//Longitude
var x = Centroid($feature).x
var lon = (x / originShift) * 180.0;
return lon
