URGENT- where do I find the buffer tool with end types?
7920
21
06-10-2022 02:30 AM
FraserB
https://pro.arcgis.com/en/pro-app/2.8/tool-reference/feature-analysis/create-buffers.htm
As per the website this buffer tool exists - I need the one where you can remove end types. I have used it before!! But I cannot find it now. Has it been removed? I cannot even find the standard feature analysis toolbox
https://pro.arcgis.com/en/pro-app/latest/tool-reference/feature-analysis/an-overview-of-the-standard...
This is pretty urgent, thanks !
Stefan_Thorn
You are right. when basic license the tool looks like this
With advanced it is
Stefan_Thorn
Hi @FraserB
Go to the Geoprocessing tab, search for buffer and select the tool you want
FraserB
Hi Stefan - this tool does not have the end type option?
FraserB
also there was an option where you could only choose do buffer on left side or right side etc
JohannesLindner
I believe the line end option is only available with an Advanced license.
Have a great day!
Johannes
FraserB
has that been recently updated - as I have used it before ?
JohannesBierer
According to the help pages JohannesLindner is right - you need a advanced license in Pro 2.8 and 2.9. Also in ArcMap 10.6.1 you need a advanced license ... https://pro.arcgis.com/de/pro-app/latest/tool-reference/analysis/buffer.htm
Stefan_Thorn
With advanced it is
FraserB
ok thank you. My licence must have changed from advanced to standard. I thought I was going crazy because I distinctly remembered you could change end lines etc with Arc but just could not find it! thanks for looking into it
Stefan_Thorn
in the buffer tool in the screendump you have the side option.
can you post an image what you want to achieve?
