Uploading a GeoTIF to AGOL fails everytime with no clear error message
856
11-06-2024 12:54 AM
EdHixson
HI all
Im trying to upload a GeoTIF from my ArcPro into ArcOnline but keep getting the error log attached. I am not quite sure what is causing it and im not sure if am missing some obvious as I wont work with Rasters very often.
It is tif drone imagery that has bee converted to a GeoTIF, I am trying to share it along in British National Grid in the tile layer type.
Has anyone come across this before?
All the best
-Ed
EdHixson
THank you for sharing this
yes the answer was here - Publish hosted tile layers from files—ArcGIS Online Help | Documentation
I was only able to get it uploaded via this method.
ChrisUnderwood
Hello @EdHixson , are you able to post a sample GeoTIF that shows the problem, and some brief notes on the workflow you follow to upload it ?
EdHixson
Hi there
Sharing a sample of the TIF as quite hard due to its size and the 9mb limit on here.
In regards to the work flow
- Download TIF from BIM
- Load into ArcPro project
- Use Copy raster tool to change to GeoTIF
- Make sure project is BNG and attempt to upload in empty map.
DanPatterson
MVP Esteemed Contributor
EdHixson
