Updating Spatial Reference of Map using arcpy
3212
06-22-2022 10:45 AM
CullenWilliams-Freier1
Hello!
I'm currently working on automating a workflow that involves creating various maps, nationwide, that all use different state plane coordinate systems. Does arcpy support updating the spatial reference information of the map itself? I understand how to update this information for individual layers, but I'm looking for a way to update the spatial reference information that I would normally update under the map's Properties page.
Any advice welcome, thanks!
EvanThoms
Get a handle on the map object and there is a spatialReference property you can read and write to
Map—ArcGIS Pro | Documentation
I was able to determine this was available at least as late as v2.6, but older than that, I don't know
Thanks! I did notice that, and I've been trying to work with that and cannot figure it out (novice Python user, to be sure). Would it look something like this?
#Get current spatial reference information for a map called "subjectLocationMap".
subjectLocationSR = subjectLocationMap.spatialReference
#Test to see what comes back - in this case, it's "WGS_1984_Web_Mercator_Auxiliary_Sphere"
subjectLocationSR.name
#Picking randomly, let's pretend I want to update the map's spatial reference to NAD 1983 StatePlane Arizona Central (FIPS 0202). Do I think create a string with the desired spatial reference system, then use subjectLocationSR.loadFromString()?
EvanThoms
Probably the easiest way to create a spatialReference object is to pull it from another item, such as a map or layer, as you have done in your example, but you can also create one from a .prj file, the name, or factory code and you don't need to use loadFromString. From the documentation:
sr = arcpy.SpatialReference("Hawaii Albers Equal Area Conic")
You would only need loadFromString if you only had the WKT string.
