Updating deep learning frameworks to new version
5225
13
11-03-2021 01:29 PM
MrG
Previously, I installed the deep learning frameworks on my workstation using the installer for Pro 2.6 (the installer provided by Esri that installs all the stuff, which is great!). It is up and running. and I could train models, infere and so on, without many problems.
The question is: I want to upgrade Pro to the last version compatible with the last deep learning frameworks installer. What strategy do you suggest? Upgrade first Pro and then uninstall the previous frameworks? Uninstall the previos frameworks before upgrading Pro? Upgrade Pro and then install the new frameworks on top of the old ones?
Any guidance about the order of installs and how to proceed will be appreciated. Thanks!!!
p.s.: for uninstalling the AI frameworks I suppose that the old installer has an uninstall procedure under programs >> uninstall, right?
DanPatterson
MVP Esteemed Contributor
Did you get your information from this page?
Esri/deep-learning-frameworks: Installation support for Deep Learning Frameworks for the ArcGIS Syst...
... sort of retired...
MrG
Yes. That's the installer.
DanPatterson
if there isn't an uninstaller, you could create a new environment, switch into it and install your new package.
Of post an "Issue" on their site to see if you get a response there.
MrG
"Their site"... sounds interesting... Have you got an URL?
DanPatterson
Issues · Esri/deep-learning-frameworks (github.com)
New Issue  -- to the right of the screen
MrG
Thank you!!!
MrG
After a couple of weeks, no answer at Github.
Any other hint will be appreciated!
DanPatterson
what is the github issue link?
MrG
