update a field using the values of another
2339
10-20-2023 04:54 AM
Labels (3)
davidchamberlain2
Hi all,
I have created a 'Miles' field and I want it to update as and when the ShapeLength field is changed. I cant work out a simple way to do this. I have polyline data in a database/SDE and I want to be able to edit existing and create new lines with the miles field updating as the ShapeLength field does. Can anyone help please?
Dave
Tags (3)
JakeSkinner
Esri Esteemed Contributor
Hi @davidchamberlain2,
You can do this using Attribute Rules.  Execute the Add Attribute Rule tool for your feature class.  Ex:
JakeSkinner
George_Thompson
Esri Notable Contributor
davidchamberlain2
Thank you both,
I used attribute rules and it works well.
Thank you
Dave
