Update 3.2 --> 3.3.1 - Changing contents freezes ArcGIS Pro
158
6
17 hours ago
MaxRingler1
I have just updated from 3.2 to 3.3.1 on an i9-13900, 92 GB RAM, 4 TB SSD, Win11, .NET 8.0.6 machine. Now ArcGIS goes into long term (~15-20 min) freezes (circular computing indicator) every time I am adding or removing data or when I am toggling the visibility of layers in the contents; the map can still be zoomed and panned, but all menu items and tools are greyed out. This happens across all my projects, also new test projects that I created in 3.3.1 and regardless of where the data of the layers are stored. Saving the project in 3.3.1 as a new file did not help, emptying the cache and repairing the install did also not help.
What helps is uninstalling 3.3.1 and reinstalling 3.2 - but obviously this cannot be a permanent solution.
Any suggestions?
Georgios-NektariosTselos
Hi @MaxRingler1 you will need to download Microsoft .NET Desktop Runtime 8.0.0 or a later patch. I think the older version of .NET Desktop Runtime is causing your problem.  You could also check it on the link below,
https://pro.arcgis.com/en/pro-app/latest/get-started/arcgis-pro-system-requirements.htm
Best Regards
Georgios-Nektarios Tselos
MaxRingler1
Sorry, that was a typo - it was in fact 8.0.5 - now 8.0.6 - I corrected my original post.
The faulty behaviour however remains the same unfortunately.
Ok, maybe the only thing that I can suggest to to you is to make a diagnostic check of your computer with the following  link to check one more time if everything is ok and  your Desktop can run the ArcGIS Pro
 https://www.systemrequirementslab.com/client-app?refid=1256&appkey=6D681CD0-BA6C-4B6B-9A82-639759CF...
DanPatterson
Check for WebView2
ArcGIS Pro 3.3 system requirements—ArcGIS Pro | Documentation
under software requirements, it is new to Pro 3.3
... sort of retired...
MaxRingler1
Yes, WebView 2 (126.x.x.x) is installed on the machine that has issues. In the meantime, I could also open the project on another machine that runs 3.3 (but not 3.3.1). So the problems seem to have resulted only from the latest (minor) update.
DanPatterson
Tech Support is your best bet.  3.3.1 was a minor update and they would want to examine your case.
