Union Tool Output Clean Up
2703
12-22-2021 10:38 AM
ChrisSpadi
I ran a Union between project locations and sensitive environmental areas. I then filtered out only the project sections from the Union output. The table looks like this:
My goal is to automate this portion of cleaning up the data with either python or model builder within Pro.
Goal:
- remove all fields except Title and FID_'s
- then remove the FID_ from the field name
- then replace all values -1 or below with a blank field
- then generate a report with the table in PDF format
My gut tells me python is the right approach and will have more tools for fine tuning this. I may be wrong.
Any input is much appreciated.
Thanks.
JakeSkinner
Esri Esteemed Contributor
@ChrisSpadi this can be accomplished using arcpy:
- remove all fields except Title and FID_'s  --> Delete Field
- then remove the FID_ from the field name  --> Alter Field
- then replace all values -1 or below with a blank field  -->  Calculate Field
- then generate a report with the table in PD  -->  Report.  The report template must first exist in the Pro project
JakeSkinner
ChrisSpadi
I ended up building a model with some of these tools.
DanPatterson
MVP Esteemed Contributor
are all your Project locations in 1 file? and the sensitive areas in another?
Are you interested in the actual area? or just whether there is overlap
Tabulate Intersection (Analysis)—ArcGIS Pro | Documentation
should not be overlooked either in part of your analysis or in its entirety
... sort of retired...
ChrisSpadi
Hi Dan,
Thanks for the response. This tool looks useful for 2 fc's but all my data is multiple fc's within a GDB and map.
DanPatterson
too bad, I suppose consolidating the disparate bits is out of the question, it seems like a good candidate
I don't suppose your environmentally sensitive areas are in one file? since a batch merge would take care of getting all your "projects" together
