Unexpected result exporting selected points to new feature class
1666
03-01-2023 08:38 AM
DerekMStrout
Hello Community,
My colleague just noticed that when exporting a small selection (four) of points from an existing feature class (drag select, Data > Export Features), the resulting feature class includes all points with full attribution, but rather than being placed where they were in the source, two of them have inexplicably been stacked on top of one of the others.
I was unable to reproduce this result on my machine.
ArcGIS Pro 3.1.0
Local (C:) data sources
No definition queries or other filters applied
Default Export Features settings
I will leave it there but we're happy to provide more info to anyone interested. Thank you!
temprobertcottreau131313
In this case you might try first doing Feature Class To Feature Class on the original feature class and then using Data > Export Features on the resulting feature with the desired points selected.
luckachi
I've been dealing with an issue over the past few days while trying to export a point layer and a polygon layer, each containing just a few records. Every time I export, the features get stacked on top of each other. For the points, I have to manually move them to their correct coordinates, but I can’t do anything about the polygons. Does anyone know what might be causing this? I'm using ArcGIS Pro 3.4.0.
