Unexpected behavior when accidentally renaming a table using an existing table name
3915
6
06-02-2023 04:10 PM
Bud
Legendary Contributor
ArcGIS Pro 3.1.2; mobile geodatabase
I have tables called TEST_TABLE and TEST_TABLE_2 in the same GDB.
If I accidentally try to rename TEST_TABLE_2 to TEST_TABLE, then I get an error, as expected, since we can't have two objects with the same name. The table does not get renamed.
However, on closer inspection, when I try to rename the table again, the selected rename text (for lack of a better term) gets displayed as TEST_TABLE, not as TEST_TABLE_2. It's as if TEST_TABLE_2 is actually named TEST_TABLE somewhere behind the scenes.
It's hard to explain, so I'll show it in a video:
(view in My Videos)
Why is that happening?
Thanks.
Bud
Esri Case #03357360 - Unexpected behavior when accidently renaming a table [using] an existing table name
BUG-000158857: When renaming a table or feature class in a mobile geodatabase in ArcGIS Pro, the selected rename text displays the previous attempt at renaming, even if the attempt failed.
RhettZufelt
MVP Notable Contributor
Because Pro is horrible at that kind of thing.  Any changes like that won't show until you refresh the database.....
Why it keeps the old alias instead of updating it to the new name (like the old "real" ArcCatalog does) I couldn't tell you either.  Since it takes 10 times as long, one would think that it would have the time to get it right....
R_
Bud
Regarding:
Why it keeps the old alias instead of updating it to the new name...I couldn't tell you either.
This idea is related: https://community.esri.com/t5/arcgis-pro-ideas/if-field-gets-renamed-reset-field-alias/idi-p/1153677
RhettZufelt
Similar, except that is for an attribute field rather than feature class.  At least with that one, the new name and alias are right there in front of you in the interface to decide what you want it to be.
Bud
Oops. I used the wrong URL in my previous reply. This is the one I meant to use:
Don't inherit FC alias when copy/pasting in same GDB
SOTIRIOSTRIANTOS
Refreshing the gdb is not always enough. Sometimes you have to refresh the parent folder in order to see the changes inside the gdb.
Bud
