Unable to update to ArcGIS 3.3
4879
13
05-13-2024 01:20 PM
FlightDeck
Hey all,
I am trying to update to ArcGIS 3.3 but keep running into an issue with Microsoft edge WebView 2 Runtime. Although it is installed and up to date I am unable to get past this error (image Attached). Has anyone else encountered this? How did you get past it? I am unable to uninstall it, but I can and did run a repair to no avail.
DanPatterson
MVP Esteemed Contributor
See Software Requirements
ArcGIS Pro 3.3 system requirements—ArcGIS Pro | Documentation
it needs to be installed
... sort of retired...
BlakeTerhune
MVP Frequent Contributor
More information in the ArcGIS Pro Blog.
Additionally, ArcGIS Pro 3.3 requires Microsoft Edge WebView2 Runtime version 117 or later. If it is not already installed on the machine, use the Evergreen Bootstrapper or Evergreen Standalone installer from Microsoft. Learn more in this blog.
FlightDeck
as above, It is installed and up to date.... I tried to uninstall and reinstall but uninstalling is not an option. The only option I have is to repair. Repairing Webview2 provided no change and I am still getting the error.
DanPatterson
Tech Support is your best option then.  There is nothing listed as errors or bugs for Pro 3.3 and WebView2 on the public facing support site.
JoshuaBixby
Make sure that WebView and ArcGIS Pro are both installed either Per-Machine or Per-User.  If you install WebView as one and try to install ArcGIS Pro as the other, you will get an error.
FlightDeck
I'm pretty sure both are per machine, but can you tell me how I would verify this?
Michael_Knapp
Ran into this same issue..... then installed WebView2 explicity as administrator (right-click --> Run as Administrator), then we were good.
ChelseaRozek
MVP Regular Contributor
This is what fixed it for me. I had run the installer without doing it and it didn't work. Ran it again as administrator and now I can update Pro.
ViduraGeekiyanage
Got same error. Update windows. No other option
