Unable to undo edits in offline features?
622
10-17-2018 11:32 AM
SMW_GIS
Hi. I am new to Pro.  I am using the Download Map tool in Pro to create a local copy of features from ArcGIS Online and make some edits.  I noticed that you cannot undo edits even when the data is downloaded locally.  In ArcMap you can download a local copy, make edits, undo edits, save or unsave edits before syncing to ArcGIS Online.  Is that possible in Pro?
by Anonymous User
Not applicable
Hi Steven,
Unfortunately, it looks like edits to feature services can't be undone at this time:
Filter undo and redo for editing—ArcGIS Pro | ArcGIS Desktop
But there's an Idea out there for this functionality, so I'd definitely head over there to add your input:
https://community.esri.com/ideas/15490
Hope this helps!
KoryKramer
Esri Community Moderator
Hi Steven Workman‌
The offline database will support undo/redo when ArcGIS Pro 2.4 is available in June/July.  Thanks for the patience as this capability was built out in Pro.
Cheers
