Unable to run Generalized Linear Model in ArcGIS Pro
1605
10-09-2023 05:20 AM
ReeyaShrestha
While trying to run the Generalized Linear Regression Model with ArcGIS Pro, it displayed the following error message
  File "d:\personal\mooc esri\esri_training\Resources\ArcToolbox\scripts\ga_desktop_generalizedlinearregression.py", line 29, in <module>
    explanatoryVariableMatching=get_value(6, as_value=True, val_table='glr_explanatory_variable_matching'),
  File "d:\personal\mooc esri\esri_training\Resources\ArcToolbox\Scripts\gautils\utilities.py", line 113, in run_ga_desktop_tool
    gax = get_client()
  File "d:\personal\mooc esri\esri_training\Resources\ArcToolbox\Scripts\gautils\utilities.py", line 96, in get_client
    from ga_spark.local import jobclient
  File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
  File "<frozen importlib._bootstrap>", line 982, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 925, in _find_spec
  File "<frozen importlib._bootstrap_external>", line 1423, in find_spec
  File "<frozen importlib._bootstrap_external>", line 1389, in _get_spec
  File "<frozen importlib._bootstrap_external>", line 1252, in __iter__
  File "<frozen importlib._bootstrap_external>", line 1239, in _recalculate
  File "<frozen importlib._bootstrap_external>", line 1235, in _get_parent_path
KeyError: 'ga_spark'
Failed script Generalized Linear Regression...
Failed to execute (GeneralizedLinearRegression).
How can I solve this issue?
DanPatterson
MVP Esteemed Contributor
There are 2
Generalized Linear Regression (GeoAnalytics Desktop)—ArcGIS Pro | Documentation
Generalized Linear Regression (Spatial Statistics)—ArcGIS Pro | Documentation
Which are you using? and do you have the correct licensing for it?
The keyerror suggests that you don't have access to apache spark
... sort of retired...
Robert_LeClair
Esri Esteemed Contributor
Looks like it's GeoAnalytics based upon this part of the code -
GA = GeoAnalytics Desktop tool me thinks.  It requires an Advanced license of ArcGIS Pro to run.  What is your license level?
