Unable to Get the Table. General Function Failure.
1958
02-19-2021 03:31 AM
Labels (3)
AndrewHargreaves1
I am using Pro 2.7.1 and secured Feature Services and ArcGIS Server v10.7.1.
I am unbale to access the attribute tables 'design' view in order to assess or update the schema.
I receive the below errors:
AndrewHargreaves1_1-1613734192068.pngAndrewHargreaves1_1-1613734192068.png@Anonymous User
ThomasColson
MVP Alum
Need more details. What is the source? Geodatabase? SQL? If so, what flavor of SQL? You cannot change the schema of a feature service, only the data used to publish the service. However, I see that error all the time when there is something going on in SQL that is unsupported by Pro (e.g 2 or more left joins on a view).
AndrewHargreaves1
PostGres. Feature Service from an ArcGIS Server 10.7. This schema is unlocked as shown in screenshot and I'm fairly certain I've added/deleted fields from it before. However, all I want is to be able to open the design view so as to be able to turn on/off fields for easier viewing.
