Add XY Coordinates with different units
2236
02-24-2021 02:02 PM
JackSelzer
I would like to use a tool to add decimal degrees to a collection of point features in my map. I have tried using the 'Add XY Coordinates' tool, but it is only returning values in US Feet.
There doesn't seem to be an option to change output units.
Am I missing something?
JoeBorgione
In the online help for the add xy coordinates tool online help, there is a link that points to the Output Coordinates System environment setting.  Have you given that a try to see if does what you need?
BillFox
MVP Notable Contributor
are you asking how to add a column to your table and calculate it to have lat/long from an existing column of decimal degrees?
JoeBorgione
RobertBorchert
Honored Contributor
It is a frustrating tool. I see you already accepted a solution. You can also do it in ArcMap and the calculate geometry tool and it works without the hoops
