When I open ArcGIS Pro 2.0.1, I click Create a new project - Blank. It does not do anything. If I click on an existing project it allows me to save a new one. Windows 8.1, 8GB RAm, i5.
We changed the location of the default project location and that fixed the issue. Looks like something weird regarding permissions in the default folder.
Changing the location of where the project is saved also does not help.
Type of license you have been assigned?
If it is a license that allows you to work in another location (ie named user etc) can you make one on another machine?
The last step will rule out license issues. I doubt it is with your machine, assuming that you are creating projects on a local machine and not on a network drive location
Basic License - Named User.
Another user with same configuration except for Windows 10, as similar issues but can save it if changed location of project. But this one is Windows 8.1. I am having the user test out if they change the default location of the project could be permissions within that user profile.
system requirements
http://desktop.arcgis.com/en/arcmap/latest/get-started/setup/arcgis-desktop-system-requirements.htm
for windows 8.1 you need an April 2017 update to it... Update 8.1 or switch to 10 and check the saving issue. That may be a permissions wherever you are saving problem and not related to Pro at all
