Trying to understand Export to CAD and why its now working for me
962
7
01-06-2022 10:33 AM
JasonYoung2
I have some GPS points that I have collected in a CSV format that I have had no issues at all displaying in ArcGIS Pro. Usually my work flow is
  • Add Data - Insert the CSV into the map
  • Display X, Y data - Select Lat/Long/Alt and this displays the data on the map
Now I want to be able to export this data as a DWG so I can send it over to some of our engineers to work off of but obviously I'm missing something because if I just go over to the Geoprocessing tools and select Export to CAD I get a blank document. What am I missing?
Tags (3)
ABishop
MVP Regular Contributor
Maybe try exporting the imported GPS points to a shapefile or feature class in a file geodatabase first?  Then try exporting to CAD?
Amanda Bishop, GISP
Sean_Wray
When you display X,Y values Arc assumes these are just WGS so be sure to apply the proper coordinate system to the exported file. Then try exporting to CAD.
JasonYoung2
Looks like I needed to add a CadType and RefName fields to the attribute table in order to get things to work. After doing that and adding Insert to CadType and a name to the RefName the export to CAD function works now.
ABishop
oh OK... sounds good.  Glad you got it figured out.
Amanda Bishop, GISP
Sean_Wray
ABishop
That looks like an ArcMap documentation?  I though the was in Pro?
Amanda Bishop, GISP
Sean_Wray
