Trying to test adding drone imagery getting error with the RBG image not showing
1859
12-22-2023 03:48 PM
KlimczakAlexandra
: Warning: Cannot compute flight height from input parameters. Use default value: 1.000 m. [DJI_0047]
2023-12-22T17:31:37.177: Warning: Cannot query focal length from input camera properties or built-in camera database. Use value queried from image Exif data: 10.260 mm. [DJI_0047]
The photos were taken with my DJI pro 2 mavic and the EXIF data has the altitude data and all other locational data listed
I would really love some help figuring out what the issue is. I took many more images but wanted to get the basic skill down with two image taken alongside each other at the same altitude.
Haus
Did you ever figure out a solution to this? I am getting the same error.
PaulLohr
This thread also mentions the error message, "Cannot compute flight height from input parameters."
https://community.esri.com/t5/arcgis-pro-questions/drone-ortho-imagery-tutorial-fails-with-error/m-p...
I can confirm that even though focal length information is available to the software, an error message appears stating that it is not.
Paul Lohr
Lohr Geospatial Services, Inc.
PaulLohr
The "cannot compute flight height from input parameters" error appears in the bug report linked below. The bug was supposed to have been fixed at version 3.2. I have 3.2.4 installed and am still getting the same error message.
https://support.esri.com/en-us/bug/the-ortho-mapping-wizard-in-arcgis-pro-281-returns-a-wa-bug-00014...
Case # 03790561 was opened to look into this.
Paul Lohr
