Trouble Extracting multi values to points or Extracting Values to Points
2897
7
07-25-2023 05:58 PM
Humayoun786
I am working on multiple rasters to extract values for points from these rasters. When I try to extract values for these points following error appears: 010005: Unable to allocate memory. I have tried to make another random point feature with many more points, but it works very well for them. However, when I try to do it on my main point file error comes in again. I have tried to break the file into many parts, but the error remains. I have checked the values of the attribute table, and they are fine; moreover, the coordinates are also the same. The raster files and point feature are also in the geodatabase of the project and not hiding very deep. I am lost with this error, any help is highly appreciated.
Tags (1)
David_McRitchie
In this case it would be best to follow the steps in the error code documentation. It could just be a case that the layer is too large and so will need to be split into smaller sections to process.
Hope that helps,
David
Esri UK -Technical Support Analyst
Humayoun786
Thanks for replying.
The layer is not too large, I have created a much larger layer by making more random points and it works perfectly well, only with the initial layer this error persists. I am wondering what is causing it.
David_McRitchie
Thank you for testing that. It certainly seems like a data specific issue so it would be worth speaking to the supplier of the dataset.
If you can provide a copy of it I am happy to give this a test on my environment.
David
Humayoun786
The data size is too big, I will not be able to attach it here. I am using Hensen dataset from this webpage: https://earthenginepartners.appspot.com/science-2013-global-forest/download_v1.7.html I am using tree cover data for 2000 raster files. I am using three raster files for Alaska: 70N160W, 70N150W, and 60N140W. After processing these rasters I want to extract data for my random points overlay over Alaska data.
Thank you for helping out,
Humayoun
Humayoun786
Also, I have three locations: one is in Brazil and one is in Far Eastern Russia. In other locations, extracting multi values to points works very well, even for a lot more raster files.
David_McRitchie
Hey Humayoun.
Apologies for the delay on this. I have got around to testing this and I am encountering the same issue. I think the size of the data with its fine cell size is likely to be the cause of the error so I will do some testing with this over the week.
When you say you tried splitting it into smaller sections can we confirm how small these were?
Many thanks,
David
David_McRitchie
Hey Humayoun,
Unfortunately, I am unable to get this working. I would suggest highlighting this to the data supplier to see if there is an issue with the data layer.
Many thanks,
David
