Trend Line Chart
3431
10-19-2018 11:18 AM
AndrewHargreaves2
How do I create a trend line in a line chart within ArcGIS Pro? For example, as well my line chart hitting each individual data point I would like an average trend.
DanPatterson_Retired
These are your options within ArcGIS Pro
Types of tabular charts—Charts | ArcGIS Desktop
You can use matplotlib and python which comes packaged with pro, but it requires some scripting.
Examples can be found here
Matplotlib Examples — Matplotlib 2.0.2 documentation
AndrewHargreaves2
hmmmm...OK, so you're stating I can NOT have a trend line out of the box?
the line chart or scatterplot... both require that the X-axis be a continuous variable.    If you have discontinuities in time, you might have to produce separate xy pairs to plot those (I don't use arc* anything graphing so I haven't explored at all)
Other packages which you have access to with the ArcGIS Pro's anaconda installation (ie Matplotlib) have a much broader range of graphing options.  You can also import other packages into the Anaconda distribution, but I wouldn't recommend going that route until you have to do more than the occasional graph
FloraVale
Hi wws_ahargreaves ,
Can you give me an example of a use case in which you would add a trend to a line chart?
Unless I misread Andrew's post, I think he wants an xy plot with the plot points connected (ie his trend), then he needs a regression plot through the points that make up the trend.
My definitions of xy vs line are:
xy graph: x and y represent variables on an interval/ratio scale
line plot:  x is measured on a nominal or ordinal scale
