Tool works fine when I use it normally, but configured into Arcpy throws licensing error
1761
6
04-17-2023 07:25 PM
AFackler_NAPSG
I am building a relatively simple python script to run a Geotagged Photo to Point tool, then run a few field calculations to add on some extra data. I managed to get the field calculations working, however, the Geotagged Photo to Point tool is giving me some problems.
When I run the tool on its own in the geoprocessing pane, it runs without issues. I also have ran it without problems in Modelbuilder. However, when I try to run it off Arcpy, I am greeted with the error 000824: The tool is not licensed. I have the advanced license and several extensions, but it baffles me why I can run it normally but not through Arcpy.
Below is my code sample so yall can pick it apart as needed. Thanks!
import arcpy
from sys import argv
InputFolder = arcpy.GetParameterAsText(0)
OutputFeatureClass = arcpy.GetParameterAsText(1)
arcpy.AddMessage("Running Geotagged Photos to Points")
# Geotagged Photos to Points
arcpy.management.GeoTaggedPhotosToPoints(InputFolder, OutputFeatureClass,
None, "ONLY_GEOTAGGED", "ADD_ATTACHMENTS")
AFackler_NAPSG
The issue here was that Pro needed an update. After updating to 3.1.1 it's working fine. Thanks all for your support
DanPatterson
MVP Esteemed Contributor
Is this a locally installed version of Pro?
See licensing
CheckProduct—ArcGIS Pro | Documentation
to see what it returns within and outside of a Pro session
... sort of retired...
AFackler_NAPSG
Not sure how exactly to run that tool, but Pro is locally installed version 3.0.3
Luke_Pinner
MVP Regular Contributor
Example at the bottom of the page Dan linked to.
AFackler_NAPSG
Running the tool like the example, I get "ArcGIS for Desktop Advanced license not available" which I know is wrong because I triple-checked that I have the advanced license (screenshot below). When I run arcpy.CheckProduct("arcinfo") as is in the python window, I get the message 'AlreadyInitialized'. Another development, when I run the tool from the Python window after copying the python command from the geoprocessing pane it runs fine.
DanPatterson
If you have a local install and your license is only controlled by you and not an organization, I would contact tech support since I can't find anything on the publically available support site.
I have never had an issue with licensing, regardless where I run scripts or code (notebooks, python window, spyder IDE etc).
AFackler_NAPSG
