Tool(s) for punching hole in polygon and removing space between (donut); for script
1143
05-01-2023 07:14 AM
TylerT
Greetings,
I have three whole polygons each interior to the next as shown:
Following is my desired output which is two polygons, the largest with a hole, and the smallest unchanged, and the middle sized polygon removed, leaving the annular space void between.
My psuedo code so far is:
1) Union
2) Delete Identical
This gets me to three polygons, but now need to erase the annular polygon.  Any thoughts on how to finish my psuedo code or a better tool/tools to do the job?
Thank you,
Tyler
ArcGIS Pro 3.1
SaraJL
Not sure how to do it with a script! But I would probably just edit the polygon, select the feature, and just manually delete it.
Not necessarily the most glamourous way to do it, but as long as it's considered 3 separate polygons, it's definitely the fastest! If you need an automated script/model, obviously it won't work, but sometimes I find manually deleting is just less hassle than trying to write a code for it. 😁
Good luck on your project!
TylerT
Yeah, script required, but thanks.  This will be run across tens of thousands of features, so manual is out of the question.  Pseudo code recommendations are fine.  I'll develop the code first with arcpy but ultimately would be better as SEDF (geoaccessor/geometry methods).
TylerT
One potential direction would be this pseudo code, knowing that a union on itself generates 3 internal polygons, 2 annular polygons, and one outer polygon:
1) Union
2) Find Identical, count Identical
3) Delete All even count groups
4) Delete Identical odd count groups (Delete Identical tool leaves one polygon)
Seems a little clunky, so still looking for more elegant solutions.
Tyler
