Time dependent data
2803
7
05-19-2018 11:46 PM
Axelvon_Matern
Hi!
I am making a historic map and am in need on best practice input / ideas on handling time related data. For example building features that change attributes like name or usage over time.
My solution is very cumbersome, where I have a finite number of fields for for example the name. Can I do this in  a more clever way then this:
FeatureName1
FeatureName1YEarFROM
FeatureName1YearTO
FeatureName1Source
FeatureName2
FeatureName2YEarFROM
FeatureName2YearTO
FeatureName2Source
etc etc
Problems with this solution:
- Highly inflexible and slow.
- Makes unnecessary big database.
- Can only tell ArcGIS Pro to use YearTO and YearFROM in one field for time function.
Can anyone point me in the right direction on this one?
KoryKramer
Esri Esteemed Contributor
You could maintain a feature class of your geographic data (building features so probably either polygons or points, correct?)  Because these are just storing the features, we won't duplicate those.
The attributes at different times can be maintained in a separate table in the same geodatabase, with a field that is used to relate each time record to its corresponding feature.
A good example is given here Examples of queries with the Make Query Table tool—Help | ArcGIS for Desktop for ArcMap and the same principles can be applied in ArcGIS Pro.
Cheers
KoryKramer
Cheers
Axelvon_Matern
Hi again!
I figured out (sort of) how to work with related data and made a QueryTable. Now I need to figure out how to use this table when defining a temporal label or Symbology. How do I tell the Expression Builder to find a field from the related table? I hoped the fields from the related table would be available, but no.
KoryKramer
If it is just related, you won't be able to label or symbolize on the related data.  But if you used the Make Query Table tool you should have ended up with a virtual table (a feature layer if you included the Shape field in the output) that has all the fields you need and you can use it like any other table.
We'd need to see what you have done so far and what the result was.  Screenshots will be necessary at this point.
Axelvon_Matern
Hi Kory!
After a litte sleep + your answer I think I figured out how it works. But it dont...   I did this:
1. Run "Make Query Table" with two tables: "Building" and "UseType" and added the fields I need.
2. Get an "Table initialization error! when opening the "Quary table". Is this to be expected as the table is virtual?
3. I set the time fields to "QueryTable".
4. My data do not show on the map.
5. My data show when time slider is set to "show all"
1611-01-01 01:00:00
4. My temporal dependent data wont show
Axelvon_Matern
Thanks for pointing me in the right direction Kory! I guess this is possible to do in ArcGis Pro too?
KoryKramer
You're welcome.  Yes, you can do this in Pro as well.  Cheers.
Axelvon_Matern
Oh man! I guess its about time for me to tackle the relationship part of ArcGis now then! I have kicked this can as far as I can until now...
(If anyone find him/herself in myshoes, heres a video I think is helpfull learning realationship databasing in ArcGis Pro https://youtu.be/Fo9tP9qkm8k).
