Tilting the polygons?
1274
10-21-2020 06:57 PM
hm_stella
Hi everyone!
I got a question about tilting the polygons.
Points I am using are a little bit weird. They are on a line which is not parallel to the grid. Here's the screenshot.
The green line is just to give how the points are not aligned straightly.
The problem is I made square polygons using graphic buffer tool, setting the points as the centroids.
Of course the polygons are having some gaps between each features. Like this:
Anyone knows how to fix this? Like tilting the plygons or aligning them?
DanPatterson
MVP Esteemed Contributor
I would use builtin tools
Create Fishnet (Data Management)—ArcGIS Pro | Documentation
You have a one-column multi-row grid pattern.
Or perhaps one of my sampling grids in
https://community.esri.com/people/danretired/blog/2020/05/19/polygonpolyline-tools-for-pro
PS
The apparent offset could be a map coordinate system artifact/difference from data.  If it bothers you.... turn the grid off.
... sort of retired...
