Tile web layer, cache locally error
917
12-13-2024 04:16 AM
ÅsaBlomberg
I am trying to make a cached tiled background map service on ArcGIS Online.
When I calculate size it says 59Gb, I have 550Gb free space on the harddrive but it still warns that the disk space will probably exceed available disk space. Then when i try to publish I get the error below - failed to publish web layer. Any ideas?
Bakgrundskarta Färg 2 89 WebTileLayer https://www.arcgis.com/ 2024-12-11 15:09:42 Status: InProgress StatusMessage: Publishing process started
Bakgrundskarta Färg 2 89 WebTileLayer https://www.arcgis.com/ 2024-12-11 15:09:42 Status: InProgress StatusMessage: Creating multipart tile package locally
Bakgrundskarta Färg 2 89 WebTileLayer https://www.arcgis.com/ 2024-12-11 15:09:45 Status: InProgress StatusMessage: Loaded SDE Workspaces
Bakgrundskarta Färg 2 89 WebTileLayer https://www.arcgis.com/ 2024-12-11 15:10:14 Status: InProgress StatusMessage: Failed to create tile package
Bakgrundskarta Färg 2 89 WebTileLayer https://www.arcgis.com/ 2024-12-11 15:10:16 Status: Failed ErrorMessage: Failed to publish web layer
Robert_LeClair
Esri Esteemed Contributor
Without knowing the details of your system, this is the help page for code 24087 with solutions to consider:  24087: The tile cache size that will be generated locally is likely to exceed the available disk spa...
