The difference between polygons
10841
13
04-29-2020 10:22 AM
MauriceMitchell
I have to separate polygon layers, layer 1 and layer 2. The polygons in layer 2 don't completely cover the polygons in layer 1, therefore, I'd like to create a layer 3 that are polygons that aren't overlapped. Also, I'm using ArcGIS Pro 2.4 if that matters.
Robert_LeClair
Esri Esteemed Contributor
I ran a quick Pro session to see the differences.  The first image is the 2 overlapping polygons.  The second image is the output from Symmetrical Difference.  The third image is the output from Erase.  Very different views.
Robert_LeClair
You could try the Symmetrical Difference GP tool listed here.
JoeBorgione
Cool tool Robert LeClair‌; the antithesis of intersect.  I've never noticed it before....
That should just about do it....
Robert_LeClair
It's a great (and unseen) tool for such a workflow!  Cheers!
Katie_Clark
MVP Regular Contributor
I was going to suggest the Erase tool as well, but looks like that also requires an advanced license. I'm not sure if that's a restriction for the OP, but just out of curiosity, any suggestions that wouldn't require that?
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Robert_LeClair
I found the following that describes the differences:
  1. Erase - This tool creates a feature class from those features or portions of features outside the erase feature class.
  2. Symmetrical Difference - This tool creates a feature class from those features or portions of features that are not common to any of the other inputs.
Katie_Clark
Right, but I was just curious if there would be an alternative workflow to achieve this for those that don't have an advanced license.
Best,
Katie
JoeBorgione
If you use Union, I think you could tease out those polygons that are not common to both.  I don't understand the licensing comment in the help docs that states:
  • Basic: Limited
  • Standard: Limited
  • Advanced: Yes
Robert_LeClair
MervynLotter
I think the use of "limited" in the basic and standard license is because you can only Union two files at a time. With the advanced license you can Union a bunch of files at a time.
