I am trying to use ArcGIS Pro 1.4 and able to work on it after configuring with my AGOL account.I could publish a service using ArcGIS Pro and the result is seen in my AGOL.
Some of my data is restricted and I wish to you Portal for ArcGIS along with my ArcGIS enterprise 10.5.I configured my licensing options with
License Type : Named User License
Portal for ArcGIS
URL https://myarcgisportal.myorg.com /arcgis
I get the below error after providing correct credentials
"The account could not be used to sign in because it is not authorized to use ArcGIS Pro"
ESRI article on the same issue clears up on AGOL but not Portal for ArcGIS
Error: The account could not be used to sign in because it is not authorized to use ArcGIS Pro
Stay signed in to your AGOL account from ArcGIS Pro. Then try Sign In to an Additional Portal.
It did work Jayanta.Thanks you !
