Tabulate area, failing.
346
11-30-2024 02:55 PM
JesseBrad24
I'm trying to find the area of a landcover data set inside a 1 mile buffer of nesting sites.
I have the nest sites inputted, a 1 mile buffer created and the layer of the landcover data. When I run tabulate area, it fails but doesn't give me a reason for the failure.
Is there something obvious I need to look into?
DanPatterson
MVP Esteemed Contributor
what parameters did you use?
Tabulate Area (Spatial Analyst)—ArcGIS Pro | Documentation
coordinate systems?
did you try using both inputs as rasters with the same cell size, extent and alignment?
output data location? were the inputs and the output into a locally stored geodatabase table?
There are some usual messages but you said there were none, but examine the causes
Working with Tabulate Area—ArcGIS Pro | Documentation
... sort of retired...
