Hey all,
I am trying to sort a table frame by Park Name but the Arrangement button isn't showing up. I've ran into this issue before but cannot remember what I did to reconcile it.
Any ideas?
That looks like a bug, I've never seen the tabs missing before. Can you reach out to tech support and see if they can help you and log an official bug?
In the meantime, I would close the Element pane then select another element then open the Table Frame Properties again. The pane probably got slightly out of sync. Closing the pane and switching elements will hopefully help things sync back up.
Thanks @AubriOtis ! After restarting Pro, the tab was available again. I will see if I can report as a bug.
