Table attribute permanence
1035
01-04-2022 12:57 PM
QJones
Pro 2.9, I am trying to change the order and visibility of fields.
I have successfully changed length but whenever open a new instance of the layer 'Visible' and the field order are reverted to the default.
JayantaPoddar
These properties are linked to the layer.
You should think about saving the layer as a layer file. Add the saved layer file instead of the feature class next time.
Think Location
Kanin
by Esri Contributor
Could you try changing the field order and visibility from the catalog window or catalog pane instead of the table of contents.
  • The catalog window/pane deals with feature classes in a geodatabase,which is stored in the data source.
  • The table of content deals with layers, whose configurations/modifications are only stored in that particular map. Hence, the "resetting" behavior when the same feature class is added to a new map.
Best regards,
Kanin
If this answer solved your question, please mark it as "Accept as Solution" to help others who have the same question.
